After you enable or disable certain modes and functions, you need to save the configuration, and then restart the switch for your change to take effect. This section lists parameters and indicates if they require a switch restart.
The following table lists parameters you configure in the CLI using the boot config flags command. For information on system flags and their configuration, see Boot Flag Configuration using CLI.
Flag |
Restart |
advanced-feature-bandwidth-reservation |
Yes |
block-snmp |
No |
debug-config |
Yes |
debugmode |
Yes |
dvr-leaf-mode |
No Note:
The switch does not require a restart when you enable the dvr-leaf-mode flag, as long as there is no unsupported configuration on the switch. |
enhancedsecure-mode |
Yes |
factorydefaults [config-only | reset-all-files | zero-touch | zero-touch-config-only] |
Yes |
flow-control-mode |
Yes |
ftpd |
No |
hsecure |
Yes |
ipv6-egress-filter |
Yes |
ipv6-mode |
Yes |
logging |
No |
macsec Note:
Exception: Only required on 5320 Series and 5420 Series. |
Yes |
nni-mstp |
Yes |
reboot |
No |
spanning-tree-mode |
Yes |
spbm-config-mode |
Yes |
spbm-node-scaling Note:
Exception: Only supported on 5320 Series and 5420 Series. |
Yes |
sshd |
No |
telnetd |
No |
tftpd |
No |
trace-logging |
No |
urpf-mode |
Yes |
verify-config |
Yes |
vrf-scaling |
Yes |
vxlan-gw-full-interworking-mode Note:
Exception: Only supported on 7520 Series and 7720 Series. |
Yes |
